How to Paint color to part in Nx ( Edit dissplay )
Builder
Builder
HI every body
I have part in my assembly .  I want to  paint color my part. But I want to the same when I pant color in Asembly and " make display part " Because whe I Make display part and paint color ( bule ) but after I open Assembly but It is not same color firt .( its grey color ( defaut ). How to paint color my part in Make dissplay part same Assembley. Im sory because my english is not good. Please watch my video
https://youtu.be/CRkYAHUNq8k
thanks
Re: How to Paint color to part in Nx ( Edit dissplay )
Siemens Genius Siemens Genius
Siemens Genius
Hello
the reason the tube color is not the same at all your assembly levels , is because you change the color of a component when your sub-assembly was the displayed part.
In NX , it's mean that you can have a different color at each level.
For doing what you want ( same color at all levels ) , my advice is to:
  • change the displayed part  =  the tube
  • change the color here ( of the solid body)
  • if you go back to the top level assembly , you shoudl have the same color.
Because you have already change the color at intermediate level, you can have some difficulties to understand my advice now , so my second suggestion is to discover the Synchronize Subassembly properties Tab. you can access it via the Right Mouse Button under your Sub-assembly.
Builder
Builder
Dear Buddy,
Thanks you for your support. But I dont know about your Idea. Can you help me by Video ?
or Image.
 Here's a simple video capturing what Buddy explained - using Synchronize Subassembly Properties to synchronize the lower level display properties up to a higher level.
Ben
Builder
Builder
Dear Benbroad ,
I can do it as your Idea. Thanks you very much
Smiley Very Happy
Mr. Dung
