Re: How to acess NX 12 Topology Optimization
Siemens Legend Siemens Legend
Siemens Legend
Sanjay,
I understand what your comment, I will check about the add on availability for NX 12.0.2, but the recommendation from Siemens is that you install it via the add on procedure.
Paul
Sent from my iPhone
Siemens Industry Software Limited is a limited company registered in England and Wales.
Registered number: 3476850.
Registered office: Faraday House, Sir William Siemens Square, Frimley, Surrey, GU16 8QD.
You can use the NX12.0.1 topology download in NX12.0.2
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Thank you everyone,
Am able to acess nowSmiley Happy..I rasied an IR, Support team suggested to set the following Environment Variable
UGII_USER_DIR=NXinstalleddirectory/Topology_optimization
I created this new Environment Variable and Launched NX
@Thomas_K Thankyou
Thank you for the advice. It works on me too!
