How to apply a picture to a 3D-model ?
Hello
How to apply a picture like a label to a 3D-model ?
  1. To a plain flat-surface.
  2. To a convex surface.
I tried Raster Image on 2D surface. Does it work if I want to laser engrave it and such ?
11 REPLIES 11
Re: How to apply a picture to a 3D-model ?
Hi @12131444 ,
As far I know, you can only add Raster Image on 2-D Plain surface.
Raster image is generally used to draw some profile or display image in part. Also it is grouped with other Reference Features/commands indicating this is just for reference. So I think, image can't be used in engraving.
Following video will be helpful from manufacturing point of view:
https://vimeo.com/83654051
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
You can add a Texture to any face, which can include an image file.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
What function is the texture adding ? Most functions are "Hidden".
Here is the post that is answered by @JohnRBaker , might be helpful to you:
Applying 2D image to 3D Curved surface
Samadhan
Thanks seems I need a "Studio license in older NX 5" is it still named same in modern NX 11 ?
See if you've Studio Task icon available under Render tab.
And find attached video from NX1102.
(view in My Videos)
Samadhan
You should check with your laser engraving software/hardware first to see what type of file it will accept as input.
No license for Studio Visualize.
Render-Studio Task.
Does Decal sticker use the same license?
Rob Newcomb, CAD/CNC/Simulation manager
Elmhirst Industries, Specializing in Prototype sheet metal stampings and assemblies
Production: NX 12.0.2 / Autoform r8 /WorkNC 2019 r1
Testing:NX 1855
PC: Rave Cadbeast: Intel(R) i7-4790K CPU @ 4.GHz /32gb ram /NVIDIA Quadro P2000 on Win10 Pro
