How to change bend radius in Cleanup Utility ?
Hi
I have an Ideas body conversion to NX:
- How to change bend radius R when using Cleanup Utility ?
- Now it takes the customer default's R1.4 automatically ?
- No box to enter the radius of the sheet ? How could this be ?
I have plate thickness=3mm and R3(same as sheet)
8 REPLIES 8
Re: How to change bend radius in Cleanup Utility ?
No model tree because Ideas body part...So
How can I now change the part radius from R1.4 to R3 ?
Is there some kind of material box to insert the new radius ?
Resize Blend command of Synchronous Modeling can do the work.
Ganesh Kadole
you can always use the tool Resize Bend Radius.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Does it change the Flat-Pattern's dimensions correctly when radius is changed synchronously ?
@ruud_vandenbrand: Yes..Resize Bend Radius is available in Sheet metal application. I thought Synchronous modeling command can also be helpful.  Smiley Tongue
Resize Blend Radius gives accurate result and its the right command to use.
Ganesh Kadole
@GaneshKadole: i always preffered for this kind of changes the resize blend radius because it's also changing the inside/outside radius in one action.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
@ruud_vandenbrand: Yes..exactly. Thank you for your guidence and quick reply! Smiley Happy
Ganesh Kadole
Recommended workflow is:
1. Convert to Sheet Metal
2. Resize Bend Radius
3. (Optional) Resize Neutral Factor.
     This will give you the correct K factor for the flat pattern.
