How to check sketch analysis in NX10
can someone help me to find sketch analysis in NX10 like catia we have sketch analysis.
I have a big sketch with lot of feature sketch like pocket,fillet,chamfer.when i finish the sketch it shows the input section is not valid.Please help me to solve this.
3 REPLIES 3
Re: How to check sketch analysis in NX10
There could be some self intersecting curves so the model feature is not working.
You might use the checkmate test for sketch a bit.
Best Regards
Kapil
I would recommend making more sketches, and have each sketch simpler.
I.e. have a sketch for pocket "A", and a separate sketch for pocket "B"
If your sketch has intersecting curves by design, the "region curves" or "stop at intersection" selection options can help select a valid section.
