How to connect NX v12 with TIA PORTAL v15
Hi everyone,
i try to connect NX v12 with TIA Portal v15 to create a virtual commissioning. The aim of project is to realise this without SIMIT. Siemens documentation (getting started) does not help anyway. I watched some videos on youtube to imitate but without success. Can anyone help?
thanks a lot in advance
Re: How to connect NX v12 with TIA PORTAL v15
Hi! Did you open "configure external signal". There PLCSIM Advanced is natively available for connection and virtual commissioning. I'm using it and it works great.
