How to control Aspect ration of Element.?
>> * I created the Elements with control parameter of  Aspect ratio<5 in NX9. and did the quality check and manually corrected the elements with respect to Aspect ratio of 5. Here the checking points and the results shown.
>> * After that the elements  Exported to .nas file and imported in Moldflow. and we found the Aspect ratio value as
20.46 (Image shown below)
    * We need the value of Aspect ratio<5 in Moldfow.
>> How/Where we have to correct the parameter in NX9 to get the value Aspect ratio<5 in Moldfow.?
     Kindly give your suggestions.
Re: How to control Aspect ration of Element.?
Anybody have idea to solve this issue/problem.?
did you post this question also on the simcenter form?
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
No..If u have simcenter form link. please share with me.
go to browse community and select there simcenter (is the old NX CAE)
https://community.plm.automation.siemens.com/t5/Simcenter/ct-p/Simcenter
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
@Ruud_vandenbrand Thank you..!!!
