How to control expressions with journalling?
I have created a component with expressions and I want to control the expressions giving a dialog box(input box). I used the syntax as in the attachment.
Any help on this regard is appreciated.
3 REPLIES 3
Re: How to control expressions with journalling?
Hi @Naga_Velamakuri,
You might want to post this in the NX Programming and Customization Forum.
Regards, Ben
Can you consider PTS also for this? I know i am talking a bit astray from this discussion but i think PTS could be one of the option you can try.
Best Regards
Kapil
You can find articles here, here, and here that demonstrate how to create and edit expressions through journal code.
