How to convert IGES sheet bodies to Solid bodies
Can any one help!
When i import .IGES assembly file to NX, i am getting only sheet bodies not a solid body.
How to convert that sheet bodies to solid bodies.
Ponraj
Re: How to convert IGES sheet bodies to Solid bodies
After you import do you have open faces.  Use the Examine geometry tool to find out where sheet edges are.  then try to heal and repair these areas.  Sometimes when translating between cad systems this can a be a huge undertaking.
Hello Ganesh,
Thanks for the information, which is much useful for my case
Ponraj
