How to convert STL to Solid Body
STL2SOLID.pngImported STLA question from Adam&Eva times - How to convert STL to Solid Body?
I want to show small ugopen sample.
  • Open achive and copy dll into any folder
  • Create new prt-file, Modeling, Ctrl+U - find dll and run it
  • Skip first dialog box about facet nums - it for debug
  • When you will see message with website of my company - process finished
  • Ctrl+F - but you dont see a model yet
  • Menu View->Operation->Regenerate Work will show all triangles
  • Right Mouse Button on any face -  Properties - Ok, and you will see all facet in tree
  • Menu Insert->Combine->Sew - you will get Solid Body
Limit - 2000 facets. Text STL only.
I use Parasolid database and write triangles into db directly.
