How to create a Multiple part list with 2 assembly configurations???
Hi everybody!
I have a problem with "Multiple Part list", because I have in my document an assembly with 2 configuration ( basically the diference between them is the change of a piece)...
I need to make a drafting with the 2 arrangements in separate sheets , but when I insert a "multiple part list" it appear the same in both assemblies.
They can help me???
Re: How to create a Multiple part list with 2 assembly configurations???
*Create the arrangements
*Add views (with all components) in drawing sheet.
*Create the required views
*Select the view in part navigator > RMB -- Edit > Select Object option from Hidden Components and select the components from UI to hide in the view created above
This will hide the components you selected from the view. I am not sure but we can not use reference sets in drafting as we use in assembly to show the alternate/different arrangements.
Ganesh Kadole
