How to create this surface?
Hi Friends,
I'm new to Siemens NX and I want to elevate my knowledge in it.
The following is a simple model I created in Rhino. I want to create the same in NX but I cannot create the same effect.
Can you give me a save file so I can study and learn your method?
Thanks.
4 REPLIES 4
Re: How to create this surface?
Here is a partial example using some of the exsiting geometry from your step model. The through curves is the most complicated feature. You could use some fairly simple sketches and extrudes to start this from scratch.surface_a.jpg
Kurt Neubaecker
CAD/CAM Designer
Proficient Industries
Cleveland, Ohio
i should make to sheet bodies of the curved surfaces.
The connected surface can be made with fill surface or throug curves mesh.
see movie below of the 2 options.
(view in My Videos)
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Thanks, But I didn't make anything out of the file.
can you teach me the method from the scratch?
Take a look. If you make the first feature the Current Feature( Right click the feature) you can proceed step by step through the features to follow the method.
Kurt Neubaecker
CAD/CAM Designer
Cleveland, Ohio
