How to creaw this model? Tuitorial needed. Thanks.
Ive been learning nx. And i need to learn how to create this model (attached drawing).
Pls Help. Thanks
Re: How to creaw this model? Tuitorial needed. Thanks.
Hello Meet,
You have to decide the method and visualize the things while creating the CAD models on your own. There can be many ways you can create the same model or features in the model.
If you have access to 'Learning Advantage Portal', you will find required information in 'Self Paced Courses'
https://training.plm.automation.siemens.com/mytraining/login.cfm
Ganesh
There are many solutions to each modelling problem.
Try to remove all of the radii from the drawing to see what the basic form will be. Then start working on it.
Even if we told you how we would do it - you'd probably have as many solutions as there are users and it could happen none would suit your modelling style.
Thanks. But it would be better if i got a video tutorial of creating this model in modelling.
So you want someone to model the part and record the process for you?
Come on, man.
