How to easily find overlapping lines?
Hi everyone,
Overlapping lines in a sketch makes the section not valid for extrude, how to find them and what is the recommended way to avoid creating overlapping lines?
Thank you!
Re: How to easily find overlapping lines?
If you toggle on "stop at intersection", it won't matter if the lines cross.  Should also show you where the intersection is, since the selection will "stop" there.
-Dave
It works well. Thank you!
I once used traditional hiding/deleting of redundant curves by chain selection.
Durgavajjala S.Prasad /NX 9,NX10&NX11
But the chain selection is a hidden command and is grayed out, is it deprecated?
