How to edit moldbase components in NX 10
I moved from 8.5 to 10, i was designing a mold, added a mold base, when i looked for the edit moldbase components button, there was nothing, but same i used to do with NX 8.5
Please anyone tell me, is there any way to set this button or Any other method for editing moldbase components.
Re: How to edit moldbase components in NX 10
Help me, Anyone.....there
in NX10 is not necessary use "Edit Component" button. In case you want to edit component, you can change parameter in the dialog. In the picture are mentioned name of plates and by the dialog is possible to change type of plates, dimensions etc.
