How to edit moldbase components in NX 10
I moved from 8.5 to 10, i was designing a mold, added a mold base, when i looked for the edit moldbase components button, there was nothing, but same i used to do with NX 8.5
Please anyone tell me, is there any way to set this button or Any other method for editing moldbase components.
Find it in the pictures, i need that edit mold base component option,
3 REPLIES 3
Re: How to edit moldbase components in NX 10
Pick it from the drop down list or pick it in the window and it will highlight.
I wanna add a plate, and modify some plate sizes, could you show me how to do it, in NX 10
I can't able to select any mold base plates, in the drop down list i can only select standard parts like pillar, bush, fashners.....
