How to export all parts in .iges format.
When i open the .iges file that  parts are converted as surface  which is exported in nx cad. How can i do export the all parts in single parts in .iges format. i have attached a image , thats while opening the iges file format it shows  as surface body.
Re: How to export all parts in .iges format.
Do you want to have everything in one part of just 1 body?
Your image shows only bodies that are in 1 part. so you allready have 1 part.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Yes , i want all parts as 1 body.
REGARDS,
Siva Kumar Murugavel
CADD ENGINEER
+91 9092090444
So you want all bodies as 1 body?
If you look into the assembly navigator do you have thare components/Parts?
everything to 1 body depence on the import/export quality.
If you import the part and it is splitted into multi sheet bodies you nee to sew everything.
In the step translators you can set "sew automatilly".
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
@S7,
If you're expecting imported IGES files to be solid bodies, you have to turn on Automatic Sewing of Surfaces, otherwise they will only come in as disconnected (Unsewn) sheet bodies (surfaces).
Tim
NX 11.0.2.7 MP11 Rev. A
GM TcE v11.2.3.1
GM GPDL v11-A.3.5.1
Thanks Ruud van den Brand,
i understood  but i have some confussion  on it . Can you make one video for  one part  like (sketch , extrude , blend and  hole , threads ) export as .iges and import as a single body.
@S7
Here is a movie
(view in My Videos)
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Its very useful for me. Can i save like same as single body in .prt format its possible.
 Whats the difference while save as file in .iges and export the file in .iges. Because in other cad softwares are has while saving itself we can change file format and  choose solid or surfaces. Likewise we have any option in NX 11
@S7 wrote:
For IGES, basically there is no difference between File > Save As or File > Export.
Ganesh
