Re: How to export all parts in .iges format.
The only difference is that when using Save as it will take the settings in the NX to iges definition file
By using export you can control some details for the export if you don't want that everything is exported.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
@S7:
If your question is how to control the IGES Options when using the "Save-As" method, then look for the "Options" button in the lower left during prompt for the new filename.
This will open the same Options dialog you see during File -> Export method:
HIH.
