How to export lower version JT document in NX 11?
For export JT document in NX,
I have a question How to export lower version JT document in NX11 ?
then this JT document with PMI can be read by Teamcenter visualization 9,
Thank you.
Re: How to export lower version JT document in NX 11?
In the install directory of NX there is a folder PVTRANS
Edit the file tessUG.config
line   JtFileFormat = "10"  to JtFileFormat = "9"
can also set to 90 or 91 for 9.0 or 9.1
Information at https://docs.plm.automation.siemens.com/tdoc/nx/11.0.2/nx_help/#uid:configuration_opts_setup_options
You can also make a copy of the tessUG.config file and set the location using UGII_PV_TESS_CONFIG_FILE environment variable
Steve V
Hi, Steve,
Thank you very much for your help !
