How to find the duplicate constraints
Hello
Nx 11.0 allows the duplicate constraints i.e., if a constraint is created by using shaft datum plane is made as parallel to the hole datum plane. Once again if we created this constrains then Nx is allwoing.
Is there any way to find this dulicate constraints or is there any way / settings to avoid this.
thanks in advance/
Re: How to find the duplicate constraints
Hi @Thilagaraj,
There exists ER for it already. But why to create duplicate constraints in first place ?
Only in case of 'Fix' constraint NX gives warning about it. If you have an assembly that contains considerable number of duplicate constraints, then I would suggest to export it to spreadsheet by using either 'Group by Components' or 'Group by Constraints' from constraints navigator. Using spreadsheet it will be easy to trace duplicates using conditional formatting.
Hi Thilagaraj,
Firstly while creating your constraints it is very beneficial to pay attention to the Assebly Navigator and the "Constraints" container. The Constraint Navigator will also be a help. In addition "Show and Hide Constrains" will be  great help when analyzing your conflicting issues.
Best Regards
Fred
