How to get automatic day.month.year in drawing template ?
Hello
How the code goes to automatically get the date from windows 7 computer and NX 9.0 ?
Drafting/Drawing template's autodate ?
Re: How to get automatic day.month.year in drawing template ?
There is a way to get the date in the drawing.
In de expression editor (in modeling -> Ctrl-E) create the following expressions (all type string):
MyDate      = StringUpper(dateTimeString("localTime?", True))
MyDay       = subString(MyDate, 9, 10)
MyMonth     = subString(MyDate, 5, 7)
MyYear      = subString(MyDate, 21, 25)
MyTimeStamp = MyDay + " " + MyMonth + " " + MyYear
When this is created you have 2 options.
Drawing in part file:
  • Then in Drafting pasted this text into a note: <X0@MyTimeStamp>
Master model:
  • Create a template attribute (TIMESTAMP) in de model template that is linked to the expression
  • Create a template attribute (DB_DWG_TEMPLATE_TIMESTAMP) in the drawing template.
In both cases you need to update the datum manually in the model file.
(update date in Modeling with Tools -> Update -> Update for External Change)
i don't now if there is a faster way too do this in NX 9.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
