How to get back missing group of commands
Hello to all,
I am strugling to find a way how to return an group of command named "Display" to original place as it is showed on the image bellow. The reason why I missed somewhere is because I have tried to move (drag and drop) it on the ribbon but somehow I dropped it on the  window and it is just dissapeared. I have tried to find some of it's command by 'command finder' but it shows that command is hiden.
How to reset it's location to Menu>Analysis>Display?
Best,
Danijel
Re: How to get back missing group of commands
Hi @danijelVR,
 I guess you can get this back by turning on this option back...
NX DISPLAY GRP.JPGHope this helps Smiley Happy
Hi @karthik6,
Yes! That's it.
Thank you very much.
How to add these two groups of commands to the ribbon as it's shown on the image bellow?
@danijelVR Load the 'Advanced' role from roles navigator. If you need very specific command groups with respect to each application, crate a user role and use it.
Hi @GaneshKadole,
I have already created "My Role". Would you like to help me how to add those groups to the ribbon and I will save it to my role? I have tried drag & drop method but it's possible with commands, not with the groups of command.
Do I need to manually create an empty group as a 'container'?
Best,
Danijel
@danijelVR wrote:
Hi @GaneshKadole,
Best,
Danijel
Load the user defined role. Ctrl+1 (Customize).
Commands tab > Analysis > Drag the required items to the riboon bar whenever required and save the role. Refer the following video.
(view in My Videos)
That's what I was looking for!
Thanks!
Best,
Danijel
