How to install reuse library in NX
Hi, I download reuse library from GTAC but I dont know how to install it to NX 10. Someone is able to help me?  In atchment I add screen of file which I have download.
Re: How to install reuse library in NX
Here are the couple of links which explains how to install the Machinery Library for native NX.
https://vimeo.com/85314935
https://allyplm.com/2013/03/201334how-to-install-standard-partsmachinery-library-for-native-nx/
The documentation on how to do it is rigth below the file you downloaded. In additon there is a tool at the bottom of that list of files you have up to do the install.
Scott
