How to keep Current working setting as Default NX-Setting.?
  • Presently i'm working in Part-A. for that i have changed some default setting like sketch preference, Modelling, Delay geometry,Expression.
  •  If i'm going to create an New Part-B. I want the same setting which i used for Part-A.
  • How can i save and change the Default Nx-Setting for creating the New parts.?
Re: How to keep Current working setting as Default NX-Setting.?
You can set those preferences/settings in the 'Customer Defaults' so that whenever you create a new part, those settings will be available.
Customer Defaults
Levels of customer defaults
Have a look at this post, it will be helpful.
https://community.plm.automation.siemens.com/t5/NX-Design-Forum/Difference-between-Customer-Default-...
Ganesh
Not all of your customer defaults will be used When create a new part.
This because there are part and session settings in the customer defaults.
If you use the blank template NX will take all the defaults in the new part.
The other way is the edit your model template add there all the changed settings.
If you the start then a new part nx will take all the settings of the template part into the new part (creates a copy of the template part)
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
