05-16-2018 11:21 AM
Dear Members,
I am looking for the option to link the Part-family member with an expression dynamically. Please share if there is any option to achieve it.
For example:
The part family table contains the unique entry as “Item” number. And the assembly where the member called has expression to locate. Then we can use it to filter out exact member by applying criteria.
The problem is this expression doesn’t remain associative to criteria condition or at least I am aware.
Please refer attached image for more understanding.
Thanks in advance.
NX 11 native mode
05-16-2018 12:05 PM
I presume that [lower-case] "item" is an expression in your assembly?
If so, then I think what you're seeing is the fact that the Part Family member re-selection does not generally happen automatically. There is a toolbar (or menu) command that will invoke this particular "Part Family Update". (Menu --> Assemblies --> Components --> Part Family Update) Try poking that, and see if you don't get the update you expect (and a report explaining which part family members were replaced and for which reasons.)
Within Product Template Studio, we added this Part Family Update as one of the standard update options, so if you know that a particular expression will be driving a change like this, you can automatically invoke this update whenever that expression is changed throuhg the Product Template interface.
Does that help?
05-16-2018 12:12 PM
It worked for me @TaylorAnderson, in NX11 and NX12.
05-16-2018 12:23 PM
Thanks Anderson!
Yes, it works this way.
Do we have any trigger mechanism, that makes part family update after there is change in “item” value? This will eliminate the user interaction.
We have NX-Open license but not PTS.
05-17-2018 01:15 AM
There's no out-of-the-box way to make this automatic today. (That's why we added the hooks in PTS.) But that would be a good ER. And as of a couple of months ago, I know the new Product Manager for Part Families really well. ;-)
05-24-2018 04:17 AM
Sure Andeson!
I will raise an ER.
Thank you very much.
3 weeks ago
I have a question concerning the funcionality in NX12.0.2.
In the past I already used the functionality to link the selection of the children wiht an expression in the assembly. I tired this out in NX11 and it worked but since we have NX 12.0.2 it's not working anymore like before.
Was there any change of the way of working?
That's the way I did before:
Create an Expression in the assembly then add the masterpart of the family and in the criteria I inserted e.g. Length==Length_assy. After typing in the argument, the chrildren were filtered.
Hopefully anyone can give me an advice what I'm doing wrong.
Best regards,
Christian
