How to make a curve visible again after hiding it
This may be a really dumb question, but I just couldn't figure it out myself...
The NX model given to me has curves associated with a sheet body, e.g. the leading edge and training ledge curves of an airfoil surface. In the QuickPick list, such curve is listed under "Construction Objects".
My question is, after I hide one such curve, how can I recover / let it become visible again? I just couldn't seem to be able to retrieve these curves after hiding them...
Thank you!
/Jing
Re: How to make a curve visible again after hiding it
Depends exaccly how you hid it, but from your description I'd try...
Menu -> Edit -> Show & Hide -> Show
The screen will "reverse blank" (all shown stuff will be hidden, all hidden stuff will be shown) where you can select the objects to un-hide.
Thank you, Ken_A! It comes visible once I do: Menu -> Edit -> Show & Hide -> Show All.
