How to make a solid to a sheet metal without losing colored faces ?
Hello
- Cleanup Utility makes it to a empty grey plate.
- Sheetmetal plate should be 1.0mm thick but because it is a solid model those "jogs" that are extruded \ cut are maybe 1.24mm thick around bends.
