How to make proper measurements with "Simple Measurement" ?
Hello
How to make proper measurements with "Analyse -> Simple Measurement" ?
  • When I try to create a straight "drafting"-style measurement like in picture "BLUE".
  • It will always create misaligned measurement like in picture "RED".
Re: How to make proper measurements with "Simple Measurement" ?
You need to use Projected Distance in Measure Distance
 Select the vector which is parallel to the edges.
Ganesh
When clicking " Measure distance" it pops up Simple distance ?
Weird...did you try dialog options??
Yes. That gear symbol worked.
-> So the "Gear"= dialog options. New to me.
Very useful sometimes Smiley Wink
Also you can use, File > Preferences > User Intrface (Ctrl + 2). Select 'Options' and click on arrow icon of 'Reset Dialog Memory'. It will reset the all command window to its default dialog options.
Ganesh
