How to move a view between sheets
hello,
What is the proper way to move a view between sheets. I have a dawing which contains a view with notes. I think I could try to copy and paste, but it's this the right way?
I am using NX 10.
Thanks in advance.
Re: How to move a view between sheets
Yes, you can copy views from one sheet to the another. Also you can copy paste the entire sheet and can remove the notes,views from the new (pasted) sheet as per your need.
Ganesh
Another option would be to use the NX move copy view command.
Blue highlight is a move/copy to another sheet. Note the copy Views button. This allows you to move or copy the view.
From the Part Navigator you can drag and drop or copy and paste a view from one sheet to another.
John Joyce, Manufacturing Engineer,
Senior Aerospace
NX 11.0.2.7 Vericut 8.0.3 - Statements and opinions are mine alone and do not reflect
the opinion of my employer or any other member of the human race
