How to move bend annotation leader over a disconnecting gap ?
Hi
How to move bend annotation leader over a "disconnecting gap" ? ( It is still the same orange bend line though )
Re: How to move bend annotation leader over a disconnecting gap ?
Right click the bend annotation /Edit/Specify Location in Origin...i hope i understood your question clearly.
Kapil
Leader(arrow) "select terminating object" only works when in same line... If gap(=bend line disrupted) in line it won't move the leader. Why ?
Got your point... Sorry i too could not achieve it.
Best Regards
Kapil
To me the only alternative seems like you can remove the leader of the annotation and make it aligned (to the centerline). Would be good to file a ER (if there is no solution to it).
Btw if you are interested then you can use the Aligned setting.
Kapil
