How to place Creation Date on a drawing (in title block)?
Hello!
First of all, I don't have a clue about the programming. So I really hope, that someone can help me with this problem.
Is it possible, to get the Creation Date as an attribute on a drawing?
If I look at File/Properties/Part File, I can see Creation Date parameter. But I don't know, how to get this information on a drawing (in a title block).
Does someone already has a macro, that does this?
I would really appreciate, if such macro can be shared.
Thanks.
Best REgards.
28 REPLIES 28
Re: How to place Creation Date on a drawing (in title block)?
Hello friend,
You can try this way.
First you sholud join edit your tabular note .
and then Right click to cell /settings / Common/Cell/Category/datedate.jpg
Hello.
Thanks for answering. But, your answer explains the settings for the cell. It explains, how the date will look like in this cell.
What I am searching is, how to automatically populate the cell with the date of creation.
So, when I first save my drawing, the date of creation is stored in the file. And I would like for this attrbiute to appear autamatically in my title block. I don't want to enter this manually.
In short, first save of the drawing file would populate appropriate cell in a title block.
Thanks.
Best Regards.
Okey .
Try this way friend.
First open you model-plain-1-mm-template.prt  from template file.(C:\Program Files\Siemens\NX 10.0\UGII\templates)
-Open expression menu (ctrl+2)
and decribe this strings.
MyDate = StringUpper(dateTimeString("localTime?", True))
MyDay = subString(MyDate, 9, 10)
MyMonth = subString(MyDate, 5, 7)
MyYear = subString(MyDate, 21, 25)
MyTimeStamp = MyDay + " " + MyMonth + " " + MyYear
and then save file.
(You should make this in modelling template part . Because you need to see this strings next time.)
Finally ,  in drafting right click a cell , edit cell and wirte  <X0@MyTimeStamp>.
Also if you want to make this for your own drafting templates , it's possible with same way.
Hello!
First, thanks for this option with expressions. It works.
But, there is a problem. Date parameter, defined with expressions, changes every day. Yesterday I have created a part with this date expression. But when I opened this same part today, the date has changed. So, it doesn't show me the date of creation, but rather the current date.
If it is possible to somehow create a date of creation (fixed date), it would be great.
Thanks.
Best Regards.
Hey friend,
Yes , you can create fixed date.
You should describe attribute in your drawing templates parts and you can fallow this way.
file/properties
New attribute
-choose category (it's optional)
-write your attribute name what you want to see
-Data Type (it's important)    :   DATE
- give your special date also time.
And then you should import your cell . That's all . Smiley Happy
Hello!
Thanks for all your help. I have just tested the option with setting the date in properties and it works. Yesterday, I have creatd a drawing and today it still show the date of creation (yesterday's date).
I have just one more question.
Is it possible, to somehow remove the time information? So, that I will have only the day/month/year written in the title block.
Thanks again.
Best Regards.
When asking questions like this, PLEASE include the version of NX that you're running.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Okey.
version is NX 10 .
Wanted to try this but when click insert attribute the list always comes up empty, regardless of which category I select in the pull-down. I am currently using NX8 but the paths all seem to run the same with the exception that I only get a small amount of attributes, none of which seem to be able to import. Is there something I need to do in customer settings?
Regardless of which import option i select in the pull-down menu.
