How to recolor I-deas imported parts ?
Hello
How to recolor old I-deas imported parts ? ( Turn the color to basic metal grey )
  • Like below. Edit Object Display -> Color. Does not work.
Re: How to recolor I-deas imported parts ?
Hi @12131444,
If different color is assigned to the different faces of the geometry then with 'Edit Object Display' command make sure you check the option 'Apply to All Faces of Selected Body' under the settings.
Ganesh Kadole
Worked. Thanks for solution.
