How to remove Time in Date Attribute
Hi all,
I want to remove Time in Date Attribute, I've tried to change Category from Text to Date in Setting, but nothing change, the time section didn't remove. Anyone know why? Below is the video that I used to reference.
https://www.youtube.com/watch?v=e0rWeH5OK1k&t=80s
Unable to play video. Please try again later.
(view in My Videos)
Re: How to remove Time in Date Attribute
Hi @Henry_Ha,
Are you mapping the text in the title block to a date attribute (perhaps mapped from Teamcenter?).
See if the following movie helps you:
(view in My Videos)
Regards, Ben
Many thank @BenBroad,
I do exactly what you guide in the video. But the time section didn't remove. I tried in another Tabular Note (not default tabular of the template drafting) then it worked. I don't know why.
Sorry, I can't send a video, I used Video Record function of NX but the video can't open (Error 0xc00d5212).
Hi @Henry_Ha,
Were you able to confirm that the text in the title block is a reference to a part attribute?
Can you post the syntax used in the cell?
Regards, Ben
Hi @BenBroad
I've just followed your video for changing date format in the title block and had the same result, it didn't actually change.
The date is taken from date attribute in the master model, which includes time automatically.
I've attached a powerpoint showing this.
Also on the same lines, I want to show part number rather than drawing number in the title block. But I can't see how to do this as it isn't an attribute of the master model that I can reference. See sheet 2 of the powerpoint.
Any help would be appreciated, regards Carl
Hi @carl_harrison
Took me a while to figure that one out Smiley Happy
You need to "version up" your title block content.  With the Title Block's layer made selectable, select "Menu > Tools > Version Up..." and select the title block.  The cells should now show the correct date format.
Regarding showing the name of the master model for the DRG NO., try entering "<W@$SH_MASTER_PART_NAME>".
Regards, Ben
Hi @BenBroad
Perfect on both counts, don't think I'd have figured those out at all!
Thanks very much, regards Carl
Siemens Legend Siemens Legend
Siemens Legend
If someone is still unable to get only Date, can use following approach which refers Date attribute and displays only date in DD-Mon-YYYY format:
  • Create a date attribute.
  • Add it in new expression: subString( ug_askPartAttrValue( "<date_attr_name>" ),1, 11)
  • Use above newly created expression to display date.
Samadhan
NX Help Links: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
