How to remove part information
Builder
Builder
Dear all,
I have found some parts in NX Documentation that none of their features has Created by and Modified by columns in part navigator. How can I remove this kind of information from my own parts?
Sina Shojaee
11 REPLIES 11
Re: How to remove part information
Hi @Sina,
Why do you want to remove such useful information, any specific reason for it?
Ganesh Kadole
Ciao @Sina
look at the refile_part.exe command as I show you in the attached image.
It should be -anonymize option
Ciao
Builder
Builder
Ciao @Cesare
Thank you for your suitable answer. I tried refile_part.exe and it works well. Do you know any other solution to remove date created and date modified information in part navigator or part history?
Sina Shojaee
Builder
Builder
Dear Ganesh
Yes. I think that kind of information is very useful. but I want to send my parts to somebody and I don't want to send my part history attached to my files
Sina Shojaee
You could try exporting part with parameters as a new part which will remove all the history except the final one.
Durgavajjala S.Prasad /NX 9,NX10&NX11
Builder
Builder
Thank you @NXplorer
You are correct. But I want to do this for thousands of parts
Sina Shojaee
You could probably automate this with a journal or API program
Builder
Builder
Dear @Ken_A
Thank you for your response. At first I tried to build a journal to export all my parts but I think NX API does not fully support this command.
Sina Shojaee
The command might not be supported by the journal recorder, but you can use the .ExportWithOptions method to export your geometry to a new file. An example can be found in this thread. It uses the "remove parameters" option, resulting in dumb bodies, but this can be changed if you want to retain the parameters.
