How to resize partlist table in drafting mode
I want to resize drafting partlist table in drafing mode  . How to increase size or reduce size ?
thank
7 REPLIES 7
Re: How to resize partlist table in drafting mode
Do you mean change the width of columns or the height of rows?
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
I mean resize all of partlist table .
thank you
A good point to start could be:
select the whole table --> rigth click --> Cell Style. On Lettering tab choose the character size best fit for you.
Bye
Fabio
I use NX10 with Gerrit Koelewijn configuration utilities. Thanks to Rob Cohon.
OK . I can not find it . i use NX9.0
thank
See attached
Fabio
Hi, In the video that you shared has helped me as well.
If the table is going long enough, then NX automatically breaks it into 2 , 3 as suitable. Is there any way in which we can bring all the pieces back to one withour affecting the width of the table?
Sachin
Change the "max height" option for the table and all the sections will be recombined into a single table.
