How to reveal the structure inside in assemblies ?
Hello
Is it "Break out view" how it works when ?:
  • I want to cut away a small piece of the cover sheet metal to reveal some particular parts inside ?
  • I have seen some "partial break out cuts" that look really nice in assemblies but I haven't learned to do these kind of special cuts just basic section views.
  • Any easy guide ? Below tic boxes are hard to understand.
4 REPLIES 4
Re: How to reveal the structure inside in assemblies ?
nice one for development to give a new fresh look.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Apart from Break Out View, Lightweight Section View and Section View in PMI application can also be used to view sub assembly/components. These views can be created based on any standard view and can be imported as base view in drafting.
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help/#uid:index_pmi:id964336Smiley Tonguemi_section_views_l...Smiley Tongue
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help#uid:index_pmi:id964336Smiley Tonguemi_menu_sectionvw_o...Smiley Tongue
@12131444 wrote:
Hello
Refer the discussion, it has the solution that you are looking for.
https://community.plm.automation.siemens.com/t5/NX-Design-Forum/Pictorial-view/m-p/397665#M12260
