How to revert to component face colours at assemblies?
How could I remove all the applied assembly level colours and make all parts displayed in their  component level colours? I want to show applied face colours at components level in every assembly.
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
6 REPLIES 6
Re: How to revert to component face colours at assemblies?
@cowski1 wrote:
https://community.plm.automation.siemens.com/t5/NX-Design-Forum/How-could-I-show-basic-part-face-col...
Above is what I was doing. I must repeat this step at each assembly level which is absurd.
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
If the component is part of a subassembly, try right clicking on the subassembly node and using properties -> assembly -> synchronize subassembly properties -> display.
Hi Mike,
There seems to be a glitch here. Depening on if you have changed the color of the component or just a couple of faces of the component at the assembly level.
- The first thing to try to do is what has been described in earlier thread - RMB on the component/components to be reset - Properties - toggle the "Specific Component Color" off .
- The second thing to try is the Part Clean Up utility - Component Display "Remove All Changes"
- The third if the two above does not work change the component color to a temporary dummy color and then RMB - Properties - toggle the "Specific Component Color" off
I suggest to file an issue with GTAC.
Best Regards
Fred
Hi @mike_fdo
To toggle off  "Specific Component Color" is still available while components multi-select.
(including un-loaded components)
 Sunkap Ahn, Senior Support Engineer
logo
We have been using the part clean up method
Brian
NX 11.0.2
Win 7 pro 64 bit
quadro k4000
