How to rotate the drawing sheet while working on the tables
i have a problem working with drawing sheet in NX i want to rotate the drawing sheet clockwise/counterclockwise while working with the tables in drawing,
is there a way to rotate the whole sheet to ease up the view of drawing table
any alternate solution would be great
using-- NX-11
Re: How to rotate the drawing sheet while working on the tables
Hi @MrX,
You can't rotate drawing sheets.
Can you upload screen shots or capture a movie showing what problems you are experiencing?
Thanks, Ben
yes please check the attached pic
just a case if you see the red highlighed box its rotated 90deg and most of the time i work on these tables to modify read or check, it becomes iritating to read these tables
As you already know, you can't rotate drawings.  And since you can't rotate a table either I suspect the Lettering Angle in these tables has been set to 90 degrees.  So, assuming that Auto Size Row and Auto Size Column were enabled, you could temporarily set the Lettering Angle back to zero, or....
Turns out you can rotate a table using "Edit > Move Object".  So perhaps rotate the table 90 degrees?
Just a thought...
(view in My Videos)
Regards, Ben
@BenBroad ya right just looking for solution to this problem!!
@Video
ha ha ha i thought of same but for me rotation of monitor is not possible so i mirror the screen with 90deg rotation as of now...
thanks,
NX11
