How to set a custom library by using UDF...
Hello all..Can anyone tell me how to set/configure a library by using user defined feature.
Re: How to set a custom library by using UDF...
Hi Kartik
following link will help you, but that is only for " Set up the Reuse Library for Custom Symbols"
https://swooshtech.com/nx-how-to-set-up-the-reuse-library-for-custom-symbols/
RRG
Thanks @RakeshGarud Smiley Happy Ok ....sure i''ll give a try and for particular Reuse Library do you knw the procedure by using user defined feature?
Check this documentation link 'Configuring UDF Libraries from NX'
Ganesh
Native NX..
