How to show hidden lines of selected parts in assembly drawing NX11
I want to show hidden lines of selected parts in assembly drawing. I am using NX11.
Actually I want to show some of the important area in which parts are mating.
can anybody help me reagrding this?
Thanks in advance.
Re: How to show hidden lines of selected parts in assembly drawing NX11
Hi @VN,
Take a look at Render Sets.
Alternatively: Break-out Section View, or Pictoral Break-out Section View
Regards, Ben
Maybe also secondary component can be a solution.
Thank you...
Using NX1876
RuleDesigner PDM
There are two methods for doing this in Drafting - render sets or secondary geometry.
Render sets give you more flexibility in the display of individual components. Secondary geometry treats all designated "secondary" components with the same display characteristics.
Here are a few links to information in the Help that describe the different methods, and example procedures:
Render sets overview
Render sets procedure
Secondary geometry overview
Tips for when to use secondary geometry representations verses render sets
Assign secondary geometry to a component and display secondary geometry in a view
