How to simulate pick & place processes by using suction pad in MCD?
Hi guys,
I'm trying to simulate machine's motion, but I meet a problem when I want to simulate pick & place process using suction pad.
Anyone knows how to make it, plz help me!
Thank you!
Re: How to simulate pick & place processes by using suction pad in MCD?
if you just want to simulate the movement you can use assembly sequence to do this.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Siemens Legend Siemens Legend
Siemens Legend
Hi Kim_boy,
you can do it with several methods, the most common and efficient is probably a "Fixed Joint".
(view in My Videos)
The Fixed Joint can be controlled via an operation.
If you want to grab an object that is not there during the start of the simulation (like from an object source) then you have detect it via a collision sensor (see attached example).
Best regards
Viktor
Hi @ViktorBraun,
Thank you so much for the tutorial of vacuum gripping. I am trying the same thing but when it's done gripping, the relevant joint to gripping gets misplaced as you can see in the attached video. Your help will be highly appreciated.
Thank you
Kazmi
(view in My Videos)
