Human Model Suppression
Hello!
I have a problem regarding human modeling in NX10.
When i create a Human in NX with
Menu -> Tools -> Human Modeling -> Human
i cannot suppess the human model by an expression. It is possible to suppress or unsuppress but i need a Suppression by an expression possibility. Just like you can do with components. Is this possible?
My second question is about measuring. When i want to measure the minimum distance between the human model and a body, it will only allow me to select a facet body of the human, but i want to select the whole human, not just a part of it. I just need the minimum distance between the whole human and another body. Is this possible?
I would be very happy about help.
Thank you!
Re: Human Model Suppression
I had no problems whatsoever setting-up a 'Suppress by Expresion' scheme for a Human model.using the normal Feature 'Suppress by Expression. workflow.
As for the measurement issue, a Human is actually composed of many individual and separate lightweight (faceted) bodies and therefore when creating a Distance measurement you can only select a single body.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
