I can not open siemens training files with htm extension.
Hi  everyone!
I am not able to open siemens trainings file. Is any able to help  me?training siemens.jpg
3 REPLIES 3
Re: I can not open siemens training files with htm extension.
More that likely it's your browser security settings. I get a popup that states "Internet Explorer restricted this webpage from running scripts or ActiveX controls". Once I select "Allow blocked content" the page loads. You probably have an ActiveX toggle in your internet options that gives the options on/off/prompt. Set them to prompt so that you can choose when to allow scripts or ActiveX content.
Regards, Ben
Hello @lukipap,
I see you are using FireFox. Might be due to that you are running the files local on you OS, so it's not a remote website. This sometimes blocks parts of websites. Like Ben Suggested, ActiveX. Not even sure if Firefox Blocks ActiveX always? Might wan to google that, and possible workarounds.
Second option is try a different browser, like InternetExplorer or Chrome.
Hope this helps.
Kind regards,
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
ActiveX is a Microsoft invention. I'm not sure that other browsers support ActiveX natively; they will probably need some sort of extension or plug in to get ActiveX stuff to run.
