I can not update assembly weight in properties
Hello everyone!
I am not able to update  weight of entire assembly in properities tab. I update data on save etc. but it isn't work. There is 2 parts in assembly ant total weight should be 73 kg but in properties of assembly it shows 0. Anyone who is able to help me?
4 REPLIES 4
Re: I can not update assembly weight in properties
When you add a block to the assembly level and then generate the weight data you will see that NX shows the weight of that body an not the complete assembly.
it looks that in the properties NX only calculaties the weight of the solid bodies that the part contains and not the bodies of the components in the assembly.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
i see also that the moment you click on update weight data that in de weight column the value is updated or placed only in the property dialog it shows 0.0000
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Hi, thanks for info. And how I can export weigh of whole assembly to the draft?
I was trying this yesterday butt wasn't able to get the weight attribute working in the assembly. You can always perform a measure body and link the expression to a attribute.
Butt it would be nicer if NX uses the same weight attribute in an assembly like the attribute in the parts
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
