I have 4pcs of jogs and due to every jog the sheet jumps ?
Hello
I have 4pcs of jogs and due to every jog the sheet jumps from the plane higher and higher why and how to fix this ?
- How to get the sheet metal plate back to the original plane ?
5 REPLIES 5
Re: I have 4pcs of jogs and due to every jog the sheet jumps ?
Hi @12131444,
You will need to edit each jog feature with proper target face and select/change height, reverse side directions accordingly.
Difficulties any video on how to make 4pcs corner jogs without plane jumping ?
Have you tried Dimple?
If you use Jog, just make sure the direction is as desired. See image below
For Dimple and Jog methods, see attached movie:
(view in My Videos)
The Dimple feature is a smart solution in this case since it's a single feature.
The reason the Jog feature moves the base in your case is that you did not flip the arrows that appear when creating the jogs. the red arrow seen in the image can be double clicked or Right-clicked to reverse what side will move, and so can the blue arrow. Try that.
Regards/ Tomas
image.pngJog Feature
