I want to mark group faces on 2D draft
Hi everyone!
I need to mark on draft group face operation (it is synchrounus operations). It is possible to make some hatching or something like that on a draft of this grouping faces??
best regards
lukipap??
Re: I want to mark group faces on 2D draft
Use 'PMI Region command' with type as 'Arbitrary'. Add new set for each face and toggle on the 'Display Crosshatch' option. You should take care of the display of crosshatch (applied to the particular model faces) by adding some note to avoid the confusion between crosshatch of the section views on the drawing and crosshatch applied to the faces of model.
Ganesh Kadole
