Import assembly settings in Customer Defaults ?
Hello
Where are Import Assembly settings in Customer Defaults ? (Teamcenter Import)
  • Like Auto Generate.
6 REPLIES 6
Re: Import assembly settings in Customer Defaults ?
Start NX through Teamcenter.
File > Import Assembly into Teamcenter
Yes. But adding the choice to Customer Defaults. So it won't change every time I import parts. Make the Auto Generate-name choice "constant".
In Customer Defaults, Teamcenter Integration for NX > Import/Export Assembly > Import tab.
How to get those selections visible ? (Must I close all parts or ?)
  • Are those selections locked for me ?
  • It only says "Suppress Dialog Box Tabs" for me ?
Based on your image it looks like those are locked at the site level. You have your filter at site and unlocked. You can try to set the filter to site(read-only) and locked and see if they show up and what they are set for. Your system administrator must have set and locked all the rest of them.
Scott
The reason you only see limited options above is because that's all that was available in NX9. Starting with NX10, there are additional customer defaults that you can see in Ganesh's screenshot.
Regards, Ben
