Import drawing preferences in NX9
I have a problem in drawing preferences in Nx9. I create a new template. In this file I have modified Drawing preferences (lines colours, arrows...).
The problem is when I load this template in older files. I have the older drawing settings. How can I get template settings in older files.
Thank you for  your feedback.
Re: Import drawing preferences in NX9
Hi @jmartinez,
I suspect your options are going to be:
  • Manually edit the preferences in each existing part file, or
  • Edit your Drafting Customer Defaults and inherit these into your existing parts.
Regards, Ben
Hi Ben,
I get it! but how can I modified Drafting Customer Defaults? The idea would be modify Drafting Customer Defaults and inherit my personalized defaults. Is that posible?
Best regards
Hi @jmartinez,
Customize the available drafting standard in the customer defaults and save as with new name. After that you can use customized drafting standard settings to inherit them into the required part files.
Solved!
Very thanks for your help.
Bests
