Importing CAM reuse library into Teamcenter
Honored Contributor
Honored Contributor
A couple years ago I found CAM_Reuse_Library_Samples.zip on the Siemens PLM download area.  If you search, you can still find it.  Even though it says "Reuse", it is NOT setup to be used by the Machinery Library import tool.  I managed to edit the tool in an earlier version, and tested it on native, and it imported corectly.
Fast forward to today, I was going to pull these into Teamcenter for our machine shop.  I also went thru the Machinery LIbrary downloads and got the latest files.  Now the latest Machinery Library install tool does not recognize the tweaks I did for the older version.  Rather than mess around with modifying the files again, is there a better way to import these files?  there are .prt, .krx, and .txt files within, and multiple folders full.
-Dave
3 REPLIES 3
Re: Importing CAM reuse library into Teamcenter
Honored Contributor
Honored Contributor
Reviving this from the depths, since the question and desire to have these imported has come up again.
Anyone done, or have thoughts on the best way to get them into Teamcenter?  the .krx and .xls files are what raise questions in my mind.
-Dave
Here is desription of what is needed in Teamcenter
Reuse in NX
Scott
Honored Contributor
Honored Contributor
I found this too, and went thru the some what tedious process.
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&p=1&q=import+krx+into+t...
-Dave
