Importing step files
I'm new on using NX. I've installed NX9.
My question is:
Is it possible to set NX doesn't create .prt files when I open/import step files ?
Or to set a temporary folder where save those .prt file ?
Re: Importing step files
Don't use NX to open / Import the Step files, use the GUI found under Translators. This will let you define a temp directory.
or just make a copy of the step file into a new folder where all the temp file can be created.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
